Ni-9213 to measure voltage
I'm using a NI-9213 device to acquire temperatures.
I'm about to buy a device measuring the pressure that will give me a +/- 1V voltage.
If I connect this new device between TC+ and COM ports in the NI-9213, will it work ?
Thanks by advance for your answers
(1,724 Views)
No - the 9213 is a specific thermocouple input module, and only accepts much smaller voltages (+/-78mV in datasheet)
Consultant Control Engineer
www-isc-ltd.com
(1,681 Views)
Thanks, but in the data sheet it's written "Channel-to-COM : +/- 1,2V"
What will happen if I plug a device delivering 0,9 V between TC0+ and COM ?
I won't be able to measure this 0,9 V ?
(1,645 Views)
You're referring to common mode voltage and not the signal
the signal range is still +/-78.125mV
Santhosh
Soliton Technologies
(1,639 Views)
