01-16-2014 07:54 AM
A simple question : Does NI Veristand run on a cRIO-9068 controller.
Thanks for the answer.
01-17-2014 07:41 AM
Hi Bob
Thanks for asking your question on NI's Forum !
Unfortunately, Veristand is not supported on the 9068 (using Zync architecture and LinuxRT OS).
You will see that it is not possible to install Veristand Engine on this target from NI MAX, as it is possible with other cRIO.
Vincent
Vincent.O
National Instruments France
Été de LabVIEW 2014
12 présentations en ligne, du 30 juin au 18 juillet
05-21-2014 11:32 PM
Unfortunately, I just bought crio 9068 and planned to run with veristand. Is there any possibilities?
06-02-2014 07:31 PM
VeriStand is supported on many of the VxWorks based controllers. Your best option is to find your local NI sales engineer and see if it is possible to exchange the cRIO-9068 for a different cRIO model. The operating system support is different enough that you will not be able to get VeriStand to run on the 9068.
