08-09-2019 05:24 AM
I would need a PXIe-7820R card and all 128 I/Os connected via SMB. When configuring the system I found two options to do this:
1. Use the NI SCB-68 HSDIO module and solder the through hole SMB connectors manually
2. The system configurator has an option for the SMB-2163 module, which already has the SMB connector and is also rack mountable which I would need.
Therefore I am having a bit of an issue.
1. Can I have the SCB-68 with the SMB connectors soldered from the factory? There is an image with the connectors soldered.
2. What functionality am I giving away if I am using the SMB-2163 module since the pinout is not the same as the pinout for the 7820R card?
08-10-2019 06:28 PM
Hello leon42,
Per the NI PXIe-7820 Getting Started guide:
NI recommends using the following cables and accessories with the NI PXIe-7820R:
You can find additional information about the cables and connectors for these cards here: NI 78xx Models: R Series Cable and Accessory Compatibility
Regarding the SMB-2163, the BNC connector blocks that NI provides all have internal circuitry that is not compatible with R Series Multifunction RIO devices, which translates into having to modify the cables/boards after buying them. More information here: BNC or SMB Connectors for R Series (NI 78xx) Devices
I don't expect the cards, modules, and cables to be shipped with additional soldering – unless it is explicitly specified in the documentation. You can contact sales or support for more information or specific concerns on how the product is shipped.
All the best,
08-12-2019 12:00 AM
Thanks for the explanation. I was a bit puzzled regarding the SMB-2163.
I am still puzzled why the SMB-2163 is a option in the NI cofigurator for PXIe-7820R if they are not compatible.
I will go with the SCB-68 and solder the connectors on, since this is the preferred option.
