NI MAX
NI MAX is not responding. What could that reason?
Thank you.
(2,328 Views)
Could you please say What test were you running before NI MAX stopped responding?
Is the issue existing now?
 Regards`
Meri Margaryan
TSE Yerevan
(2,246 Views)
Accepted by topic author ozano
One thing that you can check is if the NI Device Loader is started. To check this go to:
Control Panel > Administrative Tools > Services > NI Device Loader
Make sure it is started and try again.
Hope this helps, have a great day!
(2,234 Views)
I did not do any test before open NI MAX and I reinstalled NI MAX, the problem fixed!.
Thank you.
(2,225 Views)
Hello.
How did you install the MAX? By installing again another package i mean, DAQmx?
I have a crash reporteer when I want o open MAX to see a LIN Port but, I reinstalled the DAqmx but still the same.
(1,382 Views)
My NI MAX has a crash too, and reinstallation cannot fix it. Did you fix your problem?
Thanks.
(1,182 Views)
