03-14-2021 05:53 PM
I have a NIDAQ 6221 board and I am trying to install NI drivers on my ubuntu 18.04 system. I am trying to install as per the website here: https://www.ni.com/en-us/support/documentation/supplemental/18/downloading-and-installing-ni-driver-...
The installation has completed with no error. I am trying to run the following script:
#include <stdio.h>
#include <NIDAQmx.h>
#define DAQmxErrChk(functionCall) if( DAQmxFailed(error=(functionCall)) ) goto Error; else
int main(void)
int32 error=0;
TaskHandle taskHandle=0;
int32 read;
float64 data[1000];
char errBuff[2048]={'\0'};
// DAQmx analog voltage channel and timing parameters
DAQmxErrChk (DAQmxCreateTask("", &taskHandle));
DAQmxErrChk(DAQmxCreateAIVoltageChan(taskHandle, "Dev1/ai0", "", DAQmx_Val_Cfg_Default, -10.0, 10.0, DAQmx_Val_Volts, NULL));
DAQmxErrChk(DAQmxCfgSampClkTiming(taskHandle, "", 10000.0, DAQmx_Val_Rising, DAQmx_Val_FiniteSamps, 1000));
// DAQmx Start Code
DAQmxErrChk(DAQmxStartTask(taskHandle));
// DAQmx Read Code
DAQmxErrChk(DAQmxReadAnalogF64(taskHandle, 1000, 10.0, DAQmx_Val_GroupByChannel, data, 1000, &read, NULL));
// Stop and clear task
Error:
if( DAQmxFailed(error) )
DAQmxGetExtendedErrorInfo(errBuff,2048);
if( taskHandle!=0 ) {
DAQmxStopTask(taskHandle);
DAQmxClearTask(taskHandle);
printf("DAQmx Error: %s\n",errBuff);
return 0;
I can make the file successfully. But while running the script, it is throwing out the following error.
libnipalu.so failed to initialize
Verify that nipalk.ko is built and loaded.
Aborted (core dumped)
It will be a great help if anyone can guide me on what to do. Thanks!
03-14-2021 08:19 PM
I am using NIDAQ-6211. Sorry for the mistake.
