04-05-2013 09:17 AM
How can I set my CRIO 9076 to adjust automatically to BST?
I have have tried the various solutions offered online but to no avail.
Does this CRIO support BST?
If not why not?
04-19-2013 07:17 AM
Unfortunately this controller cannot be used with BST. While some controllers can (such as the cRIO 9082), controllers running the VxWorks operating system no longer support DST.
Options to overcome this include creating code that determines when DST has started/ended and programming the cRIO's time programatically. More information as follows:
'Local Daylight Savings Time Information'
https://decibel.ni.com/content/docs/DOC-19735
From that, on your Host you can then add or subtract an hour as required to the log that you are creating.
I also recommend taking a look at this KnowledgeBase article:
'The Current Time is Incorrect on My LabVIEW Real-Time Controller'
http://digital.ni.com/public.nsf/allkb/E9D08C9F795FF49F86256F9000040DC9
However, it is strongly recommended that a cRIO's clock is not reset for time differences, as it can cause serious issues with losing data or gaining uneccesary data, when the time changes.
05-23-2014 08:08 AM
Using LabVIEW 2011 on sbRIO and can't enable day light savings time. We are using a time server to keep the sbRIO's clock from drifting. Is this an issue with version of LabVIEW, sbRIO, or using a time server? Daylight savings option is disabled.
Matt
05-27-2014 03:45 AM - edited 05-27-2014 03:47 AM
