09-11-2018 10:22 AM
Hello everyone,
new LabView user here, so please bear with me.
I am using a cRIO 9066 on which I have several modules, including an NI 9228 Analog Input Module.
I can see every channels of every modules, but none of the Analog Inputs from the NI 9228.
Am I missing something? Driver? Faulty unit? MAX configuration?
As you can see on the screenshot, I have a drop down list on every module except on the NI 9228:
I am using LabView 2017 SP1 on a Windows 7 PC.
Thank you for your help.
09-13-2018 01:35 AM
I beleive it is because you are trying to use it in Scan mode. Add a FPGA target in the cRIO and then add the 9228 module in FPGA, you will see the channel list. You can alse see the example in the example finder.
