NI 1483 with camera Baumer HXC13
I want to use NI 1483 with camera Baumer HXC13, which is confugired for 8-tap 8 bit, with resolution 1280x1024. How can I change the example code to make it correct? I have already change in CL DATA TO PIXELS.vi to 8-tap 8-bits, and Unbundle by Name  from Pixel 0 to Pixel 7 enlarge. But all I can see in Image Window after starting the problem is black window. What else do I wrong? I would really appreciate all the help. Thank you a lot.
Message 1 of 17
(4,295 Views)
can you post the example code?
Anna Vogl
Certified LabVIEW Developer
Message 2 of 17
(4,274 Views)
Ok, I am sending labview project in Attachements.
Kind regards
Message 3 of 17
(4,272 Views)
please also post the VIs of the project.
Anna Vogl
Message 4 of 17
(4,268 Views)
Can you grab an Image correctly in NI-MAX?
Anna Vogl
Message 5 of 17
(4,267 Views)
You mean if I see camera under NI-IMAQ Devices? Actually I don't. I don't see any file from IMAQ in my Devices and Interfaces
Message 6 of 17
(4,262 Views)
But the 1483 is recognized in MAX?
Anna Vogl
Message 7 of 17
(4,258 Views)
Yes it is
Message 8 of 17
(4,254 Views)
All I get now is black image with white points. Where could be the problem? I think there is no problem with comunication with camera right now. Maybe something with resolution?14.png
Message 9 of 17
(4,226 Views)
did you check the aperture? Take a flash light (not too bright) and light directly into the lense. Does that make a difference? The topic is pretty complex and it could be a lot of reasons why the image is black....
Anna Vogl
Message 10 of 17
(4,219 Views)
