09-11-2022 11:43 PM - edited 09-11-2022 11:51 PM
Hello
I am acquiring unknown sound data for research purposes. I want to make a random check if my microphone is measuring correctly. I have a sound meter that measures SPL in dB. I am not sure how to convert the data I got from the microphone to a sound pressure level (SPL) in dB. The question here is not about the formula to compute SPL (dB) in Pa. My main question is about the relationship between the data acquired and a sound in Pascal (Pa).
Considering the data is in mV, I tried to multiply and divide it at a time by the microphone's sensitivity (in mV/Pa) to compute the SPL (dB in Pa) but the value I am getting does not seem right. I took 0.00002 Pa as a reference.
My data acquisition system comprises the following
Looking forward to your help on how to resolve this issue.
Many thanks for your time.
Jaefer
09-12-2022 08:41 AM
Use this technique,
If you could share some sample data and mic sensitivity, one can calculate these
09-20-2022 01:13 AM
Thanks Santhosh.
