04-24-2012 01:43 AM
Hi guys,
yesterday I worked with my new 9606 and I decided to format it to try ather things.
I checked to take the some network settings. But when sbRIO rebooted the address whas changed and if I try to change net address I read the attached message (Immagine 2.png).
If I try to load the software I received the second attached file (Immagine 1.png)...
What's the problems?
thanks
04-26-2012 09:52 AM
Hi fabio.intel,
it seems a communication problem, consequently you can check the connection with one of the following steps:
- if you are using point to point connection, make sure to be using a crossover ethernet cable
- test the sBrio using a DHCP connection with a router/switch
- make sure that the sBrio is in the same subnet of your host, otherwise try this procedure
Is can also be a MAX related issue. Try to use another PC, or try to repair MAX from the OS Control Panel / Programs
Andrea R.
04-26-2012 04:03 PM
Hi Andrea,
I'm sorry but I don't think it is correct what you suggest. Of course I'll try to change PC, because, how I tell you, I THINK my MAX was corrupt.
I have 3 sbRIO 9606, and I had the connection with all my sbRIO. One of these sbRIO is my master and I made a copy with "RT Create Target Disk Image VI". After that I use "RT Apply Target Disk Image VI" to prepare the second one and the third one and I had the problem I describe before.
Can you try to reproduce it?
04-26-2012 05:36 PM
Hi fabio.intel,
let me know if changing pc or restoring max, you can solve the issue. In the meanwhile I try to reproduce the encountered problem and I'll let you know.
Andrea R
05-16-2012 01:16 PM
Hello Fabio,
How are you connecting the sbRIO to your host PC? Through a switch or directly with a crossover cable?
