Medições em laboratório
Olá,
Preciso medir continuamente durante 30 dias, com registro as seguintes grandezas:
corrente, tensão e temperatura, os sinais virão de um Tc, Tp e Rtd respectivamente.
o que preciso para medir e registrar estas grandezas?
(2,037 Views)
Accepted by aaswil
Hello aaswil,
If you test is intended to run non-stop for the 30 days, I recommend a Real-Time system, indeed. I would follow the next steps:
  1. Select the controller that makes the most sense for your application. I advise getting one with DAQmx, since it can make the task easier:
  2. Read Generate and Acquire Signals in a NI CompactRIO and select the interface(s) you would like to use.
  3. Select the C series modules for your measurements and make sure they are compatible with the interface you will use: CompactRIO Modules.
  4. Refer to the NI LabVIEW for CompactRIO Developer's Guide for more information about programming best practices, and answers to the common development questions in the platform.
(1,988 Views)
