I am using the PCI 7030/6040E DAQ real-time card to acquire the temperature of two K-type thermocouple.
I have use MAX to configure two virtual input channels and set the CJC to 25 Deg. I have also connected a resistor of 50K bet the AIGND and the negative input channel(i.e channel 8 and 9).
However, when I run my VI, the temperature acquired from both the identical thermocouple is different by 4 to 5 deg. In certain time, the thermocouples also give incorrect reading. What could be the common problems.
When I test the virtual channels I configured in MAX, an error (error 10401) occurred, but, I am still able to run my VI with the virtual channels' name. And the virtual channels icon under
the Data Neighbourhood do not show crosses. Is this the cause of the inaccurary readings? How can such problems be solved?
I have modified the Thermocouple Measurement.VI downloaded form the website. In this VI, the AI Acquire Waveform.VI is being used. What should be the number of sample of input to be entered, inorder for the response of the temperature acquiring process to be real-time? I am currently using 10 samples for the number of samples input of the VI, and it take quite a while to see the changes of the temperature.
Why is it that, even there is no contact with the thermocouple, the temperature acquired each time is different?
I don't not used any SCXI or SCC devices, can i accuracy acquired temp without the help of these device. What is the main purpose of these devices?
