Measurement 4-20mA current signal using NI9207
Hi,I measuremented 4-20mA current signal using CompactRIO NI9063 RT-controller and NI9207 module。The attachment are the Vi and the Circuit diagram。But I read the current value is error(actual signal is 4mA,but the Vi indicate is 0.0039),Anyone know the reason?
(1,991 Views)
Probably the software is already doing a conversion step somewhere.  In a 4-20 mA system 4mA is a zero reading from the sensor.
(1,981 Views)
Accepted by topic author Baili
Thank you!
I have solved the problem。Beasue NI9207 read the signal unit is A, so the data need to multiply by 1000 to convert mA。
(1,963 Views)
