12-14-2017 06:20 AM
I am analyzing a new cRio based system and would like some help with the MTBF values. I have many of the components but not 9036, 9031 or 9207: can anybody suply figures for these?
Also, only a single value is given for the multi-channel Do / DIO modules, and I assume the same for the AI; I really need to be able to split this between failures which affect all channels and the failure rate for a single channel. Has this this been analyzed?
Thanks for your help.
12-14-2017 09:44 AM
You should open a Service Request on ni.com/support
If that information isn't publicly findable (which I assume we've done some searching online/through content) then you are going to need an Applications Engineer to reach out to R&D internally. I recommend opening a request and getting that process started.
-Bear
12-14-2017 09:58 AM
Many thanks for the reply. I will see what I can do - it may be tricky as I am a consultant and the client is not very savvy about reliability. !
