06-11-2014 01:06 PM
I'm moving an application from a CRIO 9073 to CRIO 9074. The application runs on the scan engine with one vi on the FPGA to run the serial I/O module. On the new machine am having trouble with the "Open FPGA VI Reference" Node pointing to the VI running on the FPGA: The "Open FPGA VI Reference" returns the error "-61017 LabVIEW FPGA: You must recompile the VI for the selected target."
I have recompiled (repeatedely) the vi for the new CRIO 9074 target.
Details: Labview 2010, FPGA 10.0.0
In the "Configure Open FPGA VI Reference" the target is the vi "FPGA target 2\4-port serial.vi" , the option "bind FPGA host reference to type definition" is selected, and the path to "C:\Documents ... \FPGA\901x DMA FPGA Reference.ctl" is specified.
I've attached the scan engine VI that tries to get the reference while running "Init"
Any suggestions?
06-12-2014 03:58 PM
Hi PESobol,
Do you still see this issue if you point to the bitfile rather than the VI? Also, there's a related issue documented here that's worth looking at. Try unbinding that type definition or creating a new copy and see if this resolves the issue.
