10-06-2017 08:27 AM
Hi everybody,
I am looking for a device that can analyze MIMO signals. I have found the following device but I am not sure if this device is also appropriate for MIMO signals or not?
http://www.ni.com/white-paper/52324/en/
10-09-2017 02:44 PM
Hi Amir2,
For prototyping purposes, the following white paper discusses methods and systems for analyzing MIMO signals: http://www.ni.com/white-paper/52382/en/.
But since you linked to a VSA, will you be needing a calibrated instrument for your MIMO signal analyzer?
Regardless, if you are looking to build a MIMO test system, I would highly encourage you to call in and speak with someone to ensure you're getting the device that best fits your application and need: http://www.ni.com/contact-us/en-us
The PXIe-5668R could work but could also potentially be overkill depending on how you are wanting to analyze the signals. Besides that, there are also a lot of other considerations like frequency range, the need for synchronizing multiple analyzer channels, desired MIMO setup (2x2, 4x4, etc.?), testing a specific standard or creating custom waveforms, etc.
If you are able to give more information on your application/needs either here or when you call in, that will help determine which device would work best for you.
10-09-2017 05:11 PM
Thank you for detailed explanation. We are at the starting points for our application and its testbed desgin. I will reach out you in the future. Thanks.
