MAX Checking Your Software Compatibility LV & LV RT not required
I would like to modify the connexion parrameters of a cRIO-9073 with a deployment computer (without LabVIEW and LabVIEW Real-time installed) under MAX 15.0(Measurement & Automation Explorer). But as I connect the cRIO-9073, I'm unable to find it with the Troubleshooting Remote System Discovery. LabVIEW and LabVIEW Real-time installed seem to be not required but as I click on the Next button in the wizard nothing happens: Just a continuous hourglass. (see the screenshot)
I wish I did not have to install LabVIEW and LabVIEW Real-time because I have an application in executable form.
Ideas?
(2,482 Views)
Accepted by Totov
If you installed it on the cRIO, you should have a web configuration available.  Just put the cRIO's IP Address in a web browser.
GCentral
(2,474 Views)
Thank you
(2,452 Views)
