07-09-2018 07:28 AM
Hello!
I'm trying to create a package to use with the CompactRIO (Linux RT). This package has some vi's that call a linux shared library located in my project folder (Windows system).
When I manually copy the .so file into the CRIO, everything works fine.
The problem is that I need to copy or deploy this .so automatically, in other words, I want to install my Package and make it copy the .so file into the CRIO automatically.
How can I do this? Can anyone help me?
Thank you in advance!
07-10-2018 03:35 AM
Do you want to deploy your application into many CompactRIO?
As far as I remember, RAD Utility duplicate not only your application but also required library.
Please try it out : )
07-10-2018 07:01 AM - edited 07-10-2018 07:31 AM
Yes, the idea is be able to install this package using VI Package Manager (in Windows or even Linux environment) and use it in any CRIO. It will works like a LabVIEW library, where I can create a project and run it in CRIO.
@Tepig wrote:As far as I remember, RAD Utility duplicate not only your application but also required library.
Thank you! I'll take a look!
07-17-2018 01:43 PM
It's not what I'm looking for... 😕 If anyone have any other idea, would be great!
Thank you!
