06-16-2019 09:50 AM
how can write and read more than one information send by interface labview to stm32f4 board ?
my problem is how can multifois control a stm32f407 boards.
I use NI-VISA write and read to write and read information but I need to read 3 or 4 data each time write and read the result
I want answers and I'm ready for any explanation
you find a simple montage explains what I do
06-16-2019 08:56 AM
Hello
first of all i wish you a good day and thank you for the explanation on the questions imposed.
my problem is how can multifois control a stm32f407 card.
06-16-2019 02:55 PM
Do not use bytes at port, but use an endcharacter.
Tell VISA to read more bytes then you expect and it will stop at the specified end character e.g. a new line character.
Search for the C:\Program Files (x86)\National Instruments\LabVIEW 2018\examples\Instrument IO\Serial\Continuous Serial Write and Read.vi
Maybe it is in your installation in another folder.
06-16-2019 03:42 PM
the proleme is that the visa read and write only the type string but the data is of numeric type, in this case I use the converter as indicated in the image attach question and it works well but when I want to read and write more only one data does not work.
do I need to do independent case structure and how ?
do you have an idea?
06-16-2019 03:53 PM
Hello sir
I need help
I am using the stm32 card I would like to communicate with labview interface.
i used uart communication with adapator ttl usb
I can read and write a single data but I can not read more than
can you help me read and write more than one data
thank you in advance
06-17-2019 08:18 AM
All variables in LabVIEW can be flattened to string and the bytes can be send by VISA.
But flattening to string is adding a typedescriptor so what you really need is the typecast of a variable to string.
That also is possible. So if you send what variable you want to transmit we can help you.
06-17-2019 11:27 AM
Nope. The Flatten To String does NOT add any type descriptor unless you are flattening a variant (the descriptor is actually part of the variant data). But if you flatten a single byte, the string will contain only that byte. I actually prefer using Flatten To String and Unflatten From String because you can set the endianness of the string. There is also the option with arrays and string whether or not to include the sizes of the array/string in the flattened string.
06-17-2019 02:28 PM
06-18-2019 05:06 AM
thank you for your interaction with this question, to explain my problem: regarding the sending and receiving data, I use typecast to convert the veriable TO STRING is well resolved but the problem when I need more than one entry c ' is to say I sent and received 4 or 5 variable the question
how is it possible to read a single variable each time and display the result then go on to the second and even read and display until the 4 data ends?
is it preferable to use sequence structure or does the Write Visa and Read Visa 4 successive times?
I thank you again
06-18-2019 08:57 AM
Adding an endcharacter is not possible when writing and reading binary data, soyou need to use a fixed number of bytes.
You probably know exactly which data types in which order to expect. If not send the length or type of each transfer as a first byte.
Then read just one byte and after that the number of bytes identified in the first byte.
