LabVIEW does not allow me to add SBRIO to project, but SBRIO shows up in MAX
Ruhmann I'm thinking that might be the case. I'm guessing everything hasn't properly been installed. I'll update this after I install NI-RIO 3.3.1. I'm currently uninstalling NI-RIO 3.2.1.
Message 11 of 16
(2,452 Views)
Accepted by topic author Mahir
I think Rhumann and I were posting our replies at the same time. 🙂
Seeing that last screenshot, I'm confident that Rhumann is correct.  You do have NI-RIO installed, but it looks like it was installed before LabVIEW 2009, so the installer did not install the components necessary to support LabVIEW 2009.  If you run the NI-RIO installer again, it will not reinstall everything, but you can ensure that the check box for LabVIEW 2009 support is checked to get the support you need.  When it is installed correctly, you should see CompactRIO and NI Single-Board RIO as target types in the Add Target dialog boxes.
Spex
To the pessimist, the glass is half empty; to the optimist, the glass is half full; to the engineer, the glass is twice as big as it needs to be has a 2x safety factor...
Message 12 of 16
(2,452 Views)
Sorry to hear about your problems.  You should be seeing  more targets, with SBRIO showing up as a target.
Have you reinstalled the software, in particular the NI RIO?
I am attaching a scrren shot of the targets that my set up shows.
Cheers
Stephen
Message 13 of 16
(2,450 Views)
So what actually happened is that I downloaded the 64-bit version of LabVIEW 2009, and then installed NI-RIO (which had no compatibility with LabVIEW 2009 64-bit). After installing LabVIEW again because I found out that I'd need LabVIEW 2009 32-bit to work with the FPGA and RT 2009 modules NI-RIO compatibility was absent from LabVIEW because of the earlier 64-bit fiasco. Thanks for the help.
Please warn users that there is no 64-bit LabVIEW support for any of your other software products.
Message 14 of 16
(2,441 Views)
That's a good idea Mahir.  We will look into adding a warning to the installer if LabVIEW 64-bit is detected on the system.  Thanks for the feedback!
Message 15 of 16
(2,437 Views)
Okay now the sbRIO isn't booting up. Read this please! http://forums.ni.com/ni/board/message?board.id=170&thread.id=471390
Thanks in advance
Message 16 of 16
(2,434 Views)
