Is it possible to create a path from a RT system directly to a windows network drive?
Hello.  I would like to save an image using the IMAQ Write File 2 vi directly from a PXI running RealTime OS directly to a network share drive.  Is it possible to build a direct path?  I guess this question would be the same for saving any file type directly.  Thanks in advance.
(3,173 Views)
I wish there was support for CIFS or SMB but I'm sure there are some challenges in such an implementation for RT.  I use WebDrive to expose my RT systems as drive letters on the host side.  This is not the same as a share drive but a reasonable workaround.
(3,168 Views)
