10-01-2012 07:19 AM
Being a newbie to sbRIO, I would like to build a simple Quadrature Counter.
Recently I attended the excellent Build Your Own Embedded System Workshop and have a sbRIO-9636 which is running a modified Quadrature Counter NI example project originally designed for the sbRIO-9631. It is working great using the digital encoder built into the daughterboard.
Next I want to use the encoder of a Lego Mindstorms NXT motor (PN 9842). I will power the motor externally so for now I just want to up/down count the encoder. Here is the wiring I plan to use on my daughterboard:
Channel A (yellow wire) of the encoder will go to DI2
Channel B (blue wire) of the encoder will go to DI3
0V Common (red wire) will go to DGND
+5VDC (green wire) will go to ???
So that's my question: is there a point on the daughterboard of the sbRIO-9636 that I can safely connect to for +5VDC encoder power? By the way, these wire colors are from the Lego Mindstorms extension cables when they are cut and stripped.
Any help would be appreciated!
jimmyservo
10-01-2012 10:03 AM
According to the quick reference for the sbRIO 9636: http://www.ni.com/pdf/manuals/375933a.pdf
there appears to be +5VDC on pins 49 and 50 of the J502 connector. Is this connector available or are you using a daughterboard?
Other options would be more hackish IMO, such as drawing the 5V from the USB connector.
10-01-2012 06:49 PM
It does indeed have a daughter card, but the J502 pins are accessable from the top, so J502 it is. Thank you!
