12-09-2005 05:04 PM
The VISA names you listed indicate you looked under PXI System in MAX. There should be a group called 'NI-RIO Devices' under Devices and Interfaces. Do you see your R Series boards under that group? What are the VISA names there? They should be of the format RIOX::INSTR where X is a number. If they are there, do the following:
1) Right-click on them and select open a VISA Test Panel
2) Select the Property Node (Get) tab
3) Select Manufacturer Name from the pull down
4) Select Execute.
If VISA communication to the board is working properly you should see National Instruments returned.
12-12-2005 07:36 AM
12-12-2005 09:58 AM
