12-06-2005 02:40 PM
12-06-2005 03:27 PM
cevasp,
Are you running Windows on your PXI controller and configuring MAX directly on the PXI controller, or are you running a separate desktop computer with Windows and using LV RT on the PXI controller. Most likely you need to make a slight change in your MAX configuration so that LabVIEW (VISA) sees the FPGA devices.
Please review the following knowledgebase entries for information on this issue:
http://digital.ni.com/public.nsf/allkb/EEE781052AC0908A86256D980053734C?OpenDocument
http://digital.ni.com/public.nsf/allkb/8980356DA789165E86256F8E00462FE4
Please also review the LabVIEW FPGA release notes.
12-07-2005 06:26 AM
12-07-2005 07:52 AM
12-07-2005 08:56 AM
12-07-2005 09:11 AM
12-07-2005 09:24 AM
12-07-2005 10:12 AM - edited 12-07-2005 10:12 AM
Message Edited by cevasp on 12-07-2005 10:16 AM
12-08-2005 04:07 PM
Hmmm... That is interesting.
At this point you are able to see the 7813R in MAX but not target directly in LV, correct? A couple pieces of information that might be helpful - First, when you select the board in MAX, what is the VISA address assigned to it? Also, which slot is the board in? Have you tried moving it one of the first few slots (on the first PCI Bridge of the PXI Chassis)?
Can you compile a simple piece of code using the "Compile Only" mode and then create a host VI that targets the card using it's VISA Resource Name?
12-09-2005 07:48 AM - edited 12-09-2005 07:48 AM
Message Edited by cevasp on 12-09-2005 07:53 AM
