I have installed a new DAQ device ( Lab_pc+ board ) on my computter but I am not obtaining that this new device is recognized for the LabView. I ask for you help me.
I would like to know what LabView commands ( step-by-step)I must follow so that a new DAC board that I have installed in my computer can be used.
(3,247 Views)
Dear Sir,
In order to get your board working with labview it is important to check whether it is working with the driver (NI-DAQ). If this board is not working with labview possibly it may not be properly installed. I am appending a link to our DAQ installation wizard where you will find step by step with screen shots the procedure. Just select the operating system you have and your board (Lab-PC plus)
http://ni.com/support/daq/
Once you are sure that the board works properly with the driver, Labview will take the device number assigned in the driver (Seen at the Measurement and Automation Explorer: MAX. All the rest depends of which task would you like to do.
Hope this helps.
Thanks for contacting National Instruments!
(3,247 Views)
