How to test Analog Input NI9233 module on CompactRIO chassis 9104 with an example?
I have a CompactRIO 9104 chassis and a CompactRIO 9014 Real Time Controller. I have the following modules in it: NI9233, NI9403, NI9219, NI9205. I have installed LabVIEW 7.1, FPGA and RIO 2.3.1 . I would like to test each of the modules. However the 'Configure Target for CompactRIO' is only recognizing cRIO-9233, which is an analog input module. I had made a simple while loop in which a numeric indicator was fed from the A0 terminal of the module. This program compiled onto the FPGA, but when I ran the program, it stopped immediately. I had connected the terminal to a power supply at 3.3V. The indicator did not change and the program just stopped immediately. What can I do to test this module and why am I not able to use the other modules with this CompactRIO?
Message 1 of 1
(3,619 Views)
