11-05-2008 06:10 AM
Hi there!
When I try to compile my LabU FPGA code I got the error below.
I was able to compile the code before but with no reasons it stopped working (after a canceled compilation).
Please help.
The error message:
An internal software error has occurred. Please contact National Instruments technical support at ni.com/support with the following information:
Error 7 occurred at an unidentified location
Possible reason(s):
LabVIEW: File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS, and / on Linux. Verify that the path is correct using the command prompt or file explorer.
NI-488: Nonexistent GPIB interface.
11-05-2008 09:59 AM
Here is one thing you can try that might solve your problem. Try deleting (or renaming) the ClntTmp and SrvrTmp folders in your hard drive.
Those folders will live under NIFPGA86 (or similar, if using something different than LV 8.6). If Windows doesn't allow you to rename/delete the folders, reboot the PC.
Hope that helps.
JMota
03-09-2009 01:22 PM - edited 03-09-2009 01:23 PM
I have been getting this error a lot!!! I have been in contact with NI about the issue, but they never really gave me any real answers. I have now updated to 8.6.1 to see if that would help get rid of this problem. Didn't help!!! The crazy thing is that I have gotten this error across 4 different computers now. I thought it might be something in my project, but it seems to bomb on the example FPGA projects from NI as well. Has anyone else had serious problems with this?!?! I am out of ideas.
I always get the error at the 12% point during step 2 of the intermediate files build.
If someone here can help me, I will gladly post the email traffic I had going back-and-forth with NI Tech Support.
The crazy part is that I sent NI my entire project folder, they told me that they compiled the FPGA without any problem, so that helps me feel confident that it isn't anything particular about my project or code that is causing it to blow-up.
03-18-2009 02:13 PM
Can you check the versions of your LabVIEW, LabVIEW RT and LabVIEW FPGA in Measurement and Automation Explorer?
I have seen issues where LabVIEW 8.6 was upgraded to 8.6.1 but the Modules remained in version 8.6
06-07-2009 03:27 PM
I am having the same problem, using the embedded eval kit.
I get error 7 and error 1 every time I try to compile a vi. Even the vi from the tutorial exercise 2.
I checked in MACs and found that the version of the FPGA module is indeed 8.6. This is what was installed by the DVD that came with the eval kit. I also renamed the two directories mentioned.
To no avail...
06-12-2009 09:50 AM
Has anyone tried this solution?
http://digital.ni.com/public.nsf/allkb/CCEAE7847F41C36A86256D1F0070D224?OpenDocument
09-14-2010 12:34 PM
Yes, I tried the solution of 'My FPGA VI Compilation Fails With an Open File Error' renaming the tmp directories.
I still have the issue mentioned in the original post, stopping with a -1 'internal error', though I do not have the #7 file error, just the internal. Feels related to the installs, am scouring the 2009 SP1 with repairs to see if I can make it go away. I also had cancelled the first FPGA build (could be a cause), but am trying to figure this out on a new system/install.
09-28-2010 09:36 AM
Hi LabviewFL
did you managed to compile your FPGA code? If not or you have more questions would you please open a new thread?
Barna D.
09-28-2010 10:25 AM
Yes, my issue was solved by upgrading to NI-RIO 3.5.1
02-28-2013 06:57 AM
We had and solve this problem. For us, a DLL used by Xilinx (libBZ2.dll or similar) was overwritten by a different version by a different sw install (PowerArchiver, I think). Xilinx apparently has it's own version of the library so when we removed the windows/system32/libBZ2.dll the problem went away.
