08-06-2013 02:23 AM
I'm using sbRIO9636 and want to read anaglogue channels, I want to know that how can I select the ranges of analogue channel ? and also I've to read multiple channels with specific time?, How can i calculate conversion and sampling time?
Can anyone guide me ?
Regards
08-06-2013 08:12 PM
Hello MW_BKT,
You can set the input range of the sbRIO's analog inputs by using the "Voltage Range" property in the FPGA I/O Property node (in the FPGA VI). Put the FPGA I/O property node on your block diagram and right-click on the top purple part to select the analog input channel you want under Select Item >> FPGA Target >> Connector 0.
The sample rate is dictated by the loop time. So, if you want a sample rate of 1000 Hz, you would put a 1ms loop timer in the acquision loop.
08-23-2013 02:05 AM
Thanks alot for your help, I'll check it and let you know.
08-23-2013 02:28 AM
Thank you very much for the help, I've set the property.
regards
M.Waris
