How to enable Ethercat on a NI 9053 crio
Hi All,
Any idea how to enable ethercat on a CRIO 9053.  On this page, it says that the 9053 supports ethercat.
https://www.ni.com/en-au/support/documentation/compatibility/09/software-support-for-compactrio--com...
I have installed ethercat software which I had to do via a custom software install.  The standard package did not offer ethercat connectivity.  Using the custom software install worked fine.  I get that maybe with one ethernet connection you might have to go about configuring it slightly differently but I can't set the ethernet connection to ethercat even with the software installed, see the pic of it in MAX.
Any ideas would be much appreciated.  Thanks all 🙂
cheers
Peter
(1,763 Views)
I noticed the link I put in for some reason does not exist.
Here is another link where it says the 905x controllers are supported on ethercat
https://www.ni.com/pdf/manuals/374786l.html#supported_master
Also the lookup page which I tried to reference can be accessed here
thanks for reading.
cheers
Peter
(1,718 Views)
