10-25-2017 02:38 AM
I have an existing application that runs on a PXI, and talks to a quadrature encoder (a Sick DFS60B-TDPC10000 which can draw up to 170 mA).
My application uses a PXIe-6612 to read the encoder's signals. The PXIe-6612 also supplies power to the encoder via its +5V pin. The datasheet says that the +5V pin can supply up to 1 A current, which is plenty for the encoder.
I would now like to port the application to an IC-3173, but I'm uncertain about how to connect the encoder.
According to http://www.ni.com/pdf/manuals/375285c.pdf the encoder A and B pins should connect to Diff0+ and Diff1+ (pins 1 and 9) respectively. However, what about the power supply?
Thanks in advance!
Solved! Go to Solution.
10-26-2017 02:47 AM
@JKSH wrote:
- Do I connect a 5 V supply to VISO on the controller chassis, and then connect the "Isolated power voltage reference output" (pins 10 or 25) to the encoder's "Power Supply" pin?
- The specifications say that I mustn't draw more than 50 mA at 5V from the individual "General purpose isolated output" pins. Does this also apply to the "Isolated power voltage reference output" pins?
Answering my own question:
