03-11-2008 03:37 PM
Solved! Go to Solution.
03-12-2008 12:39 PM
Hi 1_Buck,
I'm not sure if I understand what you are asking. Would you mind explaining a bit more what you are looking to accomplish? Are you talking about remote front panels and having them run as an executable on a different machine? Hopefully, with some more information, we can help you out. Have a great day!
Carla
03-20-2008 09:42 PM
03-23-2008 09:40 PM
07-11-2008 02:52 PM
07-14-2008 09:04 AM
Hi Przemmo,
The Visible VIs section of the Real-time Properties configuration window is used to specify which VIs web browsers can access through the web server for the RT target. In order to construct the path for the VIs that you want to allow access, please consult the following help article:
Adding New Visible VIs Entries
Hopefully this points you in the right direction, and let me know if you have any further questions!
Cheers,
Jonah
07-14-2008 09:42 AM
07-15-2008 09:14 AM
If you can confirm that both of these files are working correctly, then there may be a problem with your browser setup on the PC side. What are you seeing in the browser when you try to load the address (can you take a screen shot)?
07-16-2008 02:56 AM
07-16-2008 03:49 PM
Przemmo,
In order to make the remote front panel work you do in fact need a National Instruments plugin. This is available in the LabVIEW Run-Time Engine (free download from our website) for your specific version of LabVIEW. Follow this link to the LabVIEW 8.5.1 Run-Time Engine. If you have a different version of LabVIEW please search our Drivers & Updates page for your specific LabVIEW x.x Run-Time Engine.
Also note that on the Run-time download page there are two files. If you are just using the remote front panel you can download the smaller of the two files (the minimum edition).
Download and install the run-time engine and let me know if this resolved your issue.
Cheers,
Jonah
