How do I configure IP for my NI cRIO-9073
Hi there, I have here a NI cRIO 9073 base, with PN:192172F-D4L, SN: 145DAA5.
This base after a Drive Format (LabView 8.6.1), doesn´t change IP address from 0.0.0.0 to 169.254.220.251 or pick any address from any DHCP server tryed so far!
Please, I need some help here.
Daniel.
(4,438 Views)
Daniel,
I don't think that formating the drive will do anything to the IP settings. Have you tried using the 'IP RESET' dip switch?  Manual for 9073 explains its use.
(4,404 Views)
Check out ni.com/gettingstarted for step by step tutorials of configuring a cRIO system
(4,394 Views)
I already fixed the problem.
Thanks for the help.
(4,392 Views)
So how did you do it?
(4,131 Views)
I got problem that inconsistent ip adress to connect to NI 9073 also for NI 9076 compact rio
so how to fix it
(3,205 Views)
