How do I change the Trigger source from PFI0 to PFI1
I use hardware digital trigger. The default uses PFI0 for triggering source. How can I use PFI1 as a triggering source
(1,908 Views)
Hello;
That depends on what programming language you are using to program the board. In Labview, you can set any PFI line you want to be the Dig trigger at the Trigger Config.VI.
Hope this helps.
Filipe
(1,908 Views)
Highlighted
Unfortunately, I did not use LabView. I used Visual C++ with Component Works from NI. Is there any way to switch the trigger line to PFI1?? I need to start triggering from PFI1 with start condition. Changing the wiring in the hardware is not an option in this case. Thank you very much for answering the previous question and hope to hear from you soon.
(1,908 Views)
