05-09-2019 01:02 PM
Hi All,
1. I need to connect a CSI-2 camera interface to Flexrio PXIe-7976. Is there a Custom Adapter module available?
Can I use NI-6581B custom Adapter module?
2. I need to connect FPD link III camera interface to Flexrio PXIe-7976. Is there a Custom Adapter module available? Can I use NI-6581B custom Adapter module?
CSI-2 is a Serial interface.
05-09-2019 04:50 PM
There aren't any commercial off the shelf FAMs for the 7976 that are capable of csi-2 communication. You would need to make your own FAM to do that.
Usually we recommend our high speed serial boards (the 6591 or 6592) for folks looking to implement a solution that requires a high speed serial protocol. Unfortunately there are electrical incompatibilities with csi-2 and our high speed serial boards.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kF5ISAU&l=en-US
You may want to contact the camera vendor to see if they'll recommend a frame grabber vendor for your camera.
05-12-2019 05:12 PM
05-12-2019 05:57 PM
Hi David.. Thanks for the reply. This does help in narrowing down the issue.
1. Does FAM means FPGA Adapter Module?
2. How about using NI6581B and implementing CSI-2 protocol in FPGA for acquisition?
05-13-2019 08:34 AM
Hi Waseem,
I recommend reaching out to Konrad Technologies. They have interfaces for both FPD Link III and CSI-2.
Website: https://www.konrad-technologies.com/en/
