06-09-2011 11:42 AM
Let me start by saying I'm not sure this is the right forum for this question. If you know the correct placement please let me know. I am a new LabVIEW (LabVIEW 10) user and have previously used existing code for windtunnel flow determination using pitot tubes and boundary layer probes. I am trying to include the use of hotwire anomometry, but I have no LabVIEW programming experience. Does anyone know of a basic VI to start with that I might customize? Thanks for any assistance you can provide.
Scott
Solved! Go to Solution.
06-10-2011 01:02 AM
The best way to learn would be to figure out what steps you want to take to achieve the goal and try to implement that in LabVIEW. There are lots of examples in the Example Finder (Help -> Find Examples) to get started with some basic code. After you have implemented some code, use the forums to ask questions on how you can further certain steps. That will get you an answer fast.
05-18-2012 09:35 AM
I am in a similar position to you now. Did you ever find any examplle vi's that deal with this specific problem?
