05-20-2021 07:36 AM - edited 05-20-2021 07:37 AM
The PXIe-1486 and PXIe-1487 represent a key technology capability for NI in automotive Advanced Driver Assistance Systems (ADAS) and Autonomous Drive (AD) hardware and software test applications. These six variants in total, enable FPD-Link III and GMSL2 PXI interface connectivity to modern high bandwidth ADAS/AD camera sensors and ECUs – a critical interface for transportation customers recording and playing back data to and from these DUTs. The PXIe-1486 and PXIe-1487, built upon the FlexRIO technology, enable customers to process information in real-time, synchronize multiple ADAS sensors, and stream data to the PXI backplane with PCI Express x8 Gen 3 speeds.
Driver Support
06-22-2021 08:33 AM
Hi Sam,
I am trying to run the GSML2 example but when I open the project PXie 1487 4in 4 out, it wants me to find some missing vis under <vi.lib> rvi/memory/memory_emulation. Please see attached picture. Please let me know which driver I am missing
I have on my system following installation running on my PXIe 1095
06-22-2021 03:58 PM
Hi @AsadAA -
Thanks for reaching out. First, because it's potentially easy to overlook. In the .zip file linked above, did move the CSI-2 file in the Getting Started Example folder to the <lvdir>\instr.lib\FlexRIO folder location?
06-23-2021 02:16 AM
Hi Sam.
Thanks a lot.
Actually it was a simple oversight. I had forgot to install NI FPGA module. After installing it everything work 🙂
07-12-2021 09:51 PM
Could this be distributed as part of FlexRIO?
Or maybe it could be distributed as part of NIPM of VIPM?
07-16-2021 01:02 PM
I also observed that 2020 SP1 has issues when opening the example code. I am not sure if that was the exact issue but I re-installed LabVIEW 2020 (without the SP1) and that opens with no issue.
Also, the LabVIEW project and VIs do not have source and compiled code separated. This is a best practice. This example is certainly appreciated and I look forward to trying it out on hardware. Some items will hopefully be addressed to bring it inline with other NI LabVIEW examples.
