Get path on host to calling project when running in interactive mode
Hi all.
Is there any way people know of for getting the path of the calling project when running a cRIO in interactive mode, similar to using the "Application Directory" constant in a normal source code application on a Windows host?  Using that constant when running in interactive mode gives a path on the cRIO, which makes sense given the context in which it is running, but I need to know the path of the project that is running the interactive mode session.
Thanks!
Message 1 of 1
(92 Views)
