Hardware:
cRIO 9004 with 9103 FPGA.
I am running your standard Low-Priority, High-Priority / Host PC
split-architecture to acquire data via my 9004/9103 and sending that
data via TCP/IP to my host computer.
I want to send a unique timestamp generated in the High Priority loop
with my FPGA data over the TCP/IP , but need some advice on how to
break it up and append it to my flattened string. The reason I
want to do this is that I want to generate a waveform from my data when
it gets back to my host PC. The data is in an array from my FPGA
call.
I can cobble something together, but am wondering whether someone
cleverer than I has run into this and has some advice / sample code.
Thanks!!
Wes
Wes Ramm, Cyth UK
CLD, CPLI
