Firmware too old out of the box...
When we get sbRIOs delivered from NI they always come with firmware 4.0, which unfortunately doe snto seem to be compatible with 2025 NI Max even when it comes to upgrading the firmware. The firmware has to then be upgraded gradually by connecting to them with an old NI Max version (it is not sufficient to just use an older firmware, NI Max itself has an issue doing firmware updates with the sbRIOs out of the box), and after that they can bo upgraded onwards in the 2025 toolchain...
Apart from keeping a system with an old NI Max available all the time, have anyone discovered a way to bypass this issue? It would be nice if the units got delivered with a somewhat newer firmware instead, one that was forward compatible...but even if that cannot be done due to backwards compatibility it would at leats be nice to have some tool available on a 2025-toolchain that could handle upgrades of the older firmware as well ...
(1,309 Views)
What error do you encounter when trying to upgrade the firmware using 2025 or newer MAX?
(801 Views)
Accepted by topic author Mads
It did not really provide any errors, but I figured out how to get around the issue because it was really due to the host not being recognised as a valid ssh target. By enabling the secure shell server on the device with the older firmware and then manually logging into it from the command line (ssh admin@<IP>), saying yes to accepting it as a valid ssh host..the firmware update would work. So partially it was due a new and more restrictive security setting on our network, and partially how NI Max (and RAD by the way) did not provide sufficient feedback (or even better; an option to OK the target then and there).
(662 Views)
