09-25-2017 12:15 AM
Thank you Nick,
I am logging data from analog input channel AI0 of module NI 9220 using CRIO 9035. In simulated I/O, the FPGA.vi works fine. I can see that it is reading the input from AI0. But, when I run RT.vi where the FPGA is invoked, I do not get any data and sometimes I get error code -61003(FPGA is already running). I have attached the remaining files from the project in this message.
Shantanu
09-26-2017 10:51 AM
Hi Shantanu,
I don't see any files attached to your post. Since this thread is seven years old and unlikely to get a lot of visibility, I'd recommend creating a new thread with your problem statement and your LabVIEW project attached. More people are likely to see it, and you're more likely to get responses from the community.
Thanks!
Nick
09-27-2017 03:45 AM
May be there was a problem with the upload. I am attaching the png files of the two VIs. In the FPGA VI, I am drawing the samples from the analog input. In the RT VI, I am trying to write the samples into a tdms file.
09-27-2017 05:05 PM
Could we try checking the file path input on TDMS Open VI
09-29-2017 02:05 AM
Thanks, I have created a new thread with the problem that I am facing. I am attaching the codes in this post. Just let me know if there are any files missing as these are the only three files that are attachable. I have attached a zip file with all the files. Thanks in advance
09-29-2017 07:06 PM
Hello, what is the URL to the new post you made?
10-01-2017 05:10 AM
I have also attached the project file as a zip file there. Thanks in advance.
09-03-2018 05:54 AM
HI there,
I run the tutorial as it is given on cRIO 9082 chasis. The VI run successfully but I am not able to see any data on wavefrom chart. Even TDMS file is also not showing any data. I got this error
61003
Source
niLvFpga_Run_cRIO-9082.vi
what could be the reason behind this
I tried it so many times
