03-25-2009 12:12 PM
Hello All,
The FPGA reference is giving errorr in the Host VI, if I am running the FPGA in the emulator mode. I don't have the hardware right now, so I am In emulator mode. is there any way to read data on the Host, when the FPGA is in emulator mode.
birapxi
03-25-2009 12:42 PM
03-25-2009 03:11 PM
Hello Adnan,
The broken arrow on Run is giving the error " Open FPGA VI Reference: XNode is not executable"
In details it shows the following:
"This node is not executable because an unexpected error occured during code generation."
I am running the FPGA VI on the dev computer as emulation mode. The FPGA VI works, but the HOST VI is failing to run.
birapxi
03-25-2009 10:43 PM
Configuring your FPGA Target to run on the Development Computer (with Simulated I/O) will not work if you try to run your Host VI on RT. Try dragging the VI to My Computer and run it from there.
03-26-2009 09:12 AM
What version of LabVIEW are you using?
Simulation for the FPGA Host Interface was added in LabVIEW 8.6.
If you have a prior version, you will only be able to simulate the FPGA diagram, stand alone.
Kurt
03-26-2009 10:32 AM
Hello Kurt,
I am using LabView 8.6.1
It still doesnt work.
Also when I hit the deloy button on my project explorer on the R/T VI, does it just get downloaded on the R/T processor and not run ? I had to press the Run arrow on the VI after the deployment process to actually make it run on the R/T processor. Is there any way of doing that programmtically from the VI running on my desktop remotely ? I would love to have full control of the VI's running on the R/T processor and the FPGA.
birapxi
03-26-2009 10:35 AM
Hello Adnan,
If I drag my R/T Vi to my computer, will I be able to use the FPGA VI reference?
Is that palette avaialble under my computer?
birapxi
03-26-2009 02:59 PM
03-27-2009 02:48 PM
Hello Rob,
I tried to run the VI on thePC, and still it is giving me the same error. It says that the xNode is not executable.
birapxi
03-31-2009 01:07 PM
