02-17-2009 09:50 AM - edited 02-17-2009 09:51 AM
Good Afternoon,
I am getting a compile server error that I do not know how to track down. The server is set up and working fine (LV 8.6 cRIO, FPGA) I can send over on FPGA file and it compiles fine. When the second is sent, the compile request is received and starts, but a quickly get the following pop-up:
"Status: Compilation failed due to a Compile Server error.
Regenerating IP...
ERROR:coreutil - Failure to set parameters on core: Illegal combination: Port A
Width and Port A Depth
ERROR:coreutil - Failure to generate output products
ERROR:coreutil - An error occurred while running Java. Please examine the
console or coregen log file for a specific IP related error.
If there is no specific error the problem may be due to memory limitations.
For more information please consult solution record 21955 available from:
http://www.xilinx.com/xlnx/xil_ans_display.jsp?getPagePath=21955Finished Regenerating.
ERROR:sim:57 - Error found during generation
Start Time: 2/17/2009 10:22:28 PM
End Time: 2/17/2009 10:22:54 PM"
I am aware that something is amiss in my FPGA VI, but I am unsure what the above messages are telling me to look at. Any ideas? It was working/compiling, but I changed the cRIO backplane configuration, removing some inputs and adding different ones.
02-17-2009 09:54 AM - edited 02-17-2009 09:56 AM
Sorry, I don't know how I ended up on the RT board, this will be posted to general LabVIEW - please follow there...
http://forums.ni.com/ni/board/message?board.id=170&thread.id=387522
