I tried to compile a FPGA VI with LV8.5 and the compile server stopped with this error message:
Mapping design into LUTs... ERROR:MapLib:661 - LUT2 symbol "mytop/n_3491/n_3486/n_3475/n_3467/HiCompare/BU2/U0/gen_structure_logic.gen_n onpipelined.a_lt_ge_gt_le_b.i_gen_carry_chain_comp/sel_0_mux00001" (output signal=mytop/n_3491/n_3486/n_3475/n_3467/HiCompare/BU2/U0/gen_structure_logic .gen_nonpipelined.a_lt_ge_gt_le_b.i_gen_carry_chain_comp/sel<0>) has input signal "mytop/n_3491/n_3486/n_3475/n_3467/HiCompare/b<15>" which will be trimmed. See the trim report for details about why the input signal will become undriven.
I developed the VI with LV8.2 and could compile it without any errors. The VI contains a DMA-FIFO and several analog IO operations. Can anyone tell me which part of the VI may cause that error?
I recompiled the VI with english regional settings (us + uk) and it aborted with the same error. As mentioned in the link above, I also switched off all other programms running in the background. But the error still remains.
Could the problem be solved when I use Vista instead of XP?
