07-16-2019 10:30 AM
I can recompile FPGA code on 9144 but my 9145 chassis failed to compile with same software setup. Attached xilinx log for failed compilation. Any help on this issue is much appreciated.
I am using following software
- Labview 2017 f2
- CRIO 17
- Labview FPGA 17
Following screen shot from failed compilation on 9145
And below image from successful compilation on 9144.
Solved! Go to Solution.
07-18-2019 12:14 PM
This issue got resolved after installing LV 2019 which came up with NI-9145_rev19_0.foe firmware. I was using NI-9145_rev17_0.foe came up with 2017 InCom for Ethercat, but it was throwing compilation error.
07-19-2019 04:37 PM
I'm glad you were able to figure it out! Make sure to mark your post as the solution so that other people can find it in the future!
