09-09-2014 03:57 PM
Hello all,
Currently, I have to rebuild a fpga bitfile to account for a new hardware configuration on a cRIO. I installed the appropriate tools on my computer, which were able to compile the bitfile several times; but now I am getting an error when I compile. I have attached two images of the error to this message. I am currently running this software configuration:
09-09-2014 04:09 PM
Access Denied sounds like a read-only flag is set on the file or folder.
09-09-2014 04:42 PM
That was one of my solutions. I have read write access to that folder. To test this I just copied and pasted a file in there. I've also made changes to files in the folder. When I say folder, I mean the folder that the compilation is going to send the bitfile to in the end. The VIs involved are password protected, but I have since removed the password protection, and the error is still occuring.
09-09-2014 05:34 PM
Also check the NIFPGA folder. That is where the files are actually created. On my machine it is on the root of c:\
09-17-2014 02:12 PM
It turns out that it was a firewall problem. I had turned off my firewall, but there must have been a tertiary process still running. I added some exceptions to my firewall, which should have allowed the program to work, but it didn't. Once I deleted those exceptions the compiler ran with no error again. I think it's time to get a new firewall program. Thanks for all of your help.
