08-31-2021 08:33 PM
Hi
I'm trying to save data by using NI 9234.
When I read the data saved in FIFO in Host vi, can I also check the time that the data was saved?
I wanna save the data with saved time.
Time(s) Data
0.001 1.111
0.002 0.111
0.003 2.111
like this!!
Thank you 🙂
09-01-2021 03:21 PM
You know the aquisition rate of the NI 9234 since you set it yourself. From there it should be easy to calculate the relative timestamps between the different samples. And yes, in difference to DAQmx you have to do this yourself.
Regards, Jens
09-01-2021 08:24 PM
Okay, Thank you!!
