03-29-2019 06:57 AM
I was trying to settle an EtherCAT connection with NI cRIO-9037 as the EtherCAT master and a third-party EtherCAT slave from Gantner Instruments (Q.Station 101 T), when i try to enter the active mode in the scan engine, it shows the error HEX: 0x8005442C, on the other hand if i try to manually switch the slave to safe operational state or even to bootstrap state, it shows another error (-2147138493 or in HEX: 0x80054443).
I am utilizing:
I haven't done a single block of code, i have updated both the Firmware of the cRIO and the slave in their respective softwares. The master perfectly detects the slave, so i do not think it could be the ESI File, however it won't go to the active mode of the scan engine. Could anyone lend me hand please?
04-12-2019 10:09 PM
Have you tried reformatting and reinstalling the software again?
04-14-2019 07:43 PM
Hi Nicolas_loupe,
Could you provide the Wireshark log and ESI file with me? I could help to resolve this problem when I get these files.
Thanks!
04-12-2020 07:07 PM
Did you solve this problem?
I have now the same thing with MAXPOS 50/5.
Hope you see this and can reply to me!
Thank you.
01-30-2021 03:16 AM
Anyone solved this problem?
04-13-2021 08:25 AM
In my case it was caused by the wrong address of the variable in the xml file.
I wrote the subindex in hexadecimal value while it was required in decimal value.
Check that the variables declared in the RxPDO and TxPDO of the file have the correct address.
