02-03-2006 12:43 PM
I cannot get shared variable to talk between my computer and a cRIO. They are connected by a crossover cable. I am using a project example from NI that has worked previously. All of the software is installed on the cRIO. The variable manager indicates a change from the host vi, however the cRIO does not read this change. I have tried to repaired all of the software, and reformat the
I also have noticed that the lksock.dll and nitaglv.dll along with the variables in the RT dependencies are "?". I don't know if this will help anyone.
Thank you for any help.
02-06-2006 03:41 PM
02-07-2006 05:16 PM
I have the firewall diabled. The only way I can get it to sort of work, for a small amount of time before the cRIO crashes due to no memory, is to put the shared variables on the RT target. This doesn't work all the time either. Sometimes the there are errors other no errors.
Thanks for any help.
02-08-2006 05:52 PM
Hi Squared123,
I would like to ask you a few questions inorder to isolate the cause of this issue further. Does the RT controller run out of memory even when using a simple vi with a while loop reading from a shared variable? How are you monitoring that the c-RIO is running out of memory?
