11-28-2017 07:01 AM
I have a .vi inside a fpga. This .vi has a dbl data tipe inputs, and I can't run the vi because according to the list of errors: type not supported in current tarjet.
I have a single board RIO (NI-sbRIO-9651-01c18bd6)
Does anyone know what is the problem or a possible solution?
Thanks.
Attached capture of my errors list
11-28-2017 07:26 AM
You cannot use DBLs on an FPGA. Change it to a SGL.
11-28-2017 07:33 AM
DBLs are not supported on LabVIEW FPGA. Only SGLs and only after a certain version.
11-29-2017 01:16 AM
Muchas gracias 🙂
11-29-2017 01:22 AM
Another question, the fpga can't use the Quotient & Remainder that's right? , how can i do the same operation without Quotient & Remainder
11-29-2017 03:51 AM
What are you trying to do with the Q&R? I thought it was available in FPGA, but it is expensive (lots of fabric and multiple clock cycles to complete).
11-29-2017 04:00 AM
I need to know the remainder and quotient of the division of two variables.
The fuction is in palette but when i put this in block diagram, the error list say me that this fuction is not supported
11-29-2017 04:07 AM
I want to do this
11-29-2017 05:17 AM
Quotient-Remainder is not supported in a Single Cycle Timed Loop.
You could do a repeated subtract. It will take multiple cycles but this is how certain functions are on the FPGA. What is the cycle time?
11-29-2017 05:59 AM
