Error message when formatting new cRIO 9067 - missing software objects
Dear community,
I did buy a new cRIO 9067 and wanted to install the Linux RT System Image 2022 Q3 to use the hardware with LabVIEW 2022.
Procedure:
After I select the image and click the "OK" button
it should start formatting the cRIO. Sadly I get the following error message (translated from German): At least one object of the software set was not found at the location.
Any ideas what I can do to overcome this issue?
thank you for your support!
best regards,
Mirocco
(1,156 Views)
Hi Mirocco
This error message occurs when you are trying to install software onto your offline NI real-time target running Linux, but you do not have the NI Linux Real-Time Offline Installation Support installed for the version of the NI Linux RT System Image you have selected.
For solution follow this article instructions.
Regards)
_______
Best way to thank is to give Kudos / Mark as a solution.
(965 Views)
